Civil 3D Forum
VIEWPORT TYPE
14 REPLIES 14
Message 1 of 15
3523 Views, 14 Replies
VIEWPORT TYPE
Typically when setting up a viewport in paper space I can change the viewport type at the bottom of the properties dialog box. In 2013 the option is available, but it will always snap back to undefined. I'm sure it is a setting somewhere. Any help would be appreciated. Thanks,
14 REPLIES 14
Message 2 of 15
Sinc
Interesting...  I seem to be noticing the same problem.
Guess I need to explore this and try to figure it out, since I'm supposed to be doing some training later this week in how to create P&P sheets...  I hope nothing is broken in C3D 2013.  (Luckily, I think we'll be using C3D 2012, and not C3D 2013...)
Sinc
Message 3 of 15
mathewkol
in reply to: Sinc
I am having the same problem.  No soliution yet.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 4 of 15
Sinc
in reply to: mathewkol
Kind of a bad problem...
I wouldn't be in a hurry to jump to C3D 2013 just yet.
Sinc
Message 5 of 15
mathewkol
in reply to: Sinc
Interestingly, if you open a 2012 file with that viewport already set, it stays set.  However, you can't change it in 2013.
Matt Kolberg
Message 6 of 15
BrianHailey
I've been able to duplicate the issue on my system as well.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 7 of 15
mathewkol
I submitted a case to support but I havbe yet to hear back. A fairly serious problem if you're setting up a layout for use with the section and plan production tools.
Matt Kolberg
Message 8 of 15
Cadguru42
I just tried this also and get the same problem.
I think this has been the worst release since r13.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 9 of 15
Sinc
in reply to: Cadguru42
Remember the initial release of 2007...?  Smiley Wink
Sinc
Message 10 of 15
mathewkol
Found a workaround for this. There is a new property preview sysvar PROPERTYPREVIEW. Turn it off.
Matt Kolberg
Message 11 of 15
hgohel
Thank you for reporting this defect, which is now being tracked with Defect ID 1459779.  The workaround posted by Matt Kolberg (kudos!) is the reccommended action till this is resolved.
Himanshu Gohel
Autodesk, Inc.
Message 12 of 15
Thnx man, sure helped me.
Message 13 of 15
Thanks Matt! You saved my paycheck today.
Message 14 of 15
mathewkol
Eeexcellent.
Matt Kolberg
Message 15 of 15
Thank you! I was having the same difficulty.
Rail Community
