I have a proposed utility file. In this file, the line styles say "W" for watermain, "SAN" for sanitary, etc. When I reference this file into my plan and profile sheets the line style does not carry over, instead it just shows up as a continuous line. However, when I use the NCOPY command on one of these lines, it is placed in my drawing using the correct line style.
I have the lineweight button at the bottom turned on.
Can anyone help with this?
@Anonymous wrote:I have a proposed utility file. In this file, the line styles say "W" for watermain, "SAN" for sanitary, etc. When I reference this file into my plan and profile sheets the line style does not carry over, instead it just shows up as a continuous line. However, when I use the NCOPY command on one of these lines, it is placed in my drawing using the correct line style.
Load those linetypes into your current drawing and they should work.
Verify these setting variables:
Ltscale=1
Psltscale=1
Ltscale=1
Also make sure Annotation Scaling is toggled on.
Also enter STYLE @ command line and verify the Text style associated to the Linetypes is set to a height of zero.
@Anonymous wrote:
Ltscale=1Psltscale=1
Ltscale=1
Oops not quite what I meant
Thanks for catching that Matt.
