If I have images in my dwg, and I want to temporarily use the shift key for ortho, it doesn't work. On the cammand line, it reads, "Image (s) not selected. Select Images (s) then issue command." I am not trying to manipulate an image. Why is it defaulting to an image object? TIA
Solved by Jeff_M. Go to Solution.
It does move the object ortho after a base point, but on second-click it won't set the change, and I get that message again.
