Civil 3D Forum
User Profile/Civil 3D Issues
5 REPLIES 5
ParadigmAE
1395 Views, 5 Replies
I’m having a user profile issue on one computer. I have a user, using windows 7 and AutoCAD Civil 3D 2014 on his work station. When using Civil 3D he has two issues: one, he cannot import Dgn’s. I’ve tried everything it just won’t work. Second, he cannot xref or insert PDF’s into a drawing. Now the reason why I say this is a profile issue is because if I log on to his computer (or anyone else log’s on his computer), I can do all those things in Civil 3D, import DGN’s & insert/xref PDF’s. If this user log’s on my computer, he can do all those things in Civil 3D. Import DGN’s & insert/xref PDF’s. Something with his profile on his computer is corrupt and I’m trying to fix it without deleting and creating another user profile. Does anyone have any idea’s?
5 REPLIES 5
When you say you don't want to delete/create another user profile do you mean Windows user profile or C3D profile?
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
ParadigmAE
in reply to: ParadigmAE
I mean windows profile. I'm assuming this is a windows issue. Could I be wrong?
Yes, most of the user problems we encounter are C3D profiles.
See following article: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13288548&linkID=9240697
Mike Robertson
ParadigmAE
Well thanks Mike
I'll give this a shot!!
Abraxas
Joe-Bouza
clean install maybe needed
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889713&linkID=9240697
Joe Bouza
Rail Community
