Are data shortcuts useable without being associated with a project? They don't seem to be for me. I have a drawing with just a surface on it, I name it surface.dwg. I use "Edit Data Shortcuts," then "Create data shortcut by selection" and select my surface. Now I use "Export data shortcuts to file" and name the file surface.xml. I create a new drawing file, drawing.dwg, and use the "Edit Data Shortcuts" to import the xml file, then create the reference for my surface. I save the file then close it. The next time I open drawing.dwg, no surface. The toolspace shows the surface as being present, but it is not on the drawing. If I try to synchronize from toolspace I get a message saying "Reference for surface EG is broken." In the data shortcuts vista my references have disappeared. I can bring the surface back by re-importing the xml file, then synchronizing. How can I get the shortcuts to stay there?!
Kevin
