AutoCAD Civil 3D General
Distinguished Contributor
ParadigmAE
Message 1 of 2 (137 Views)
Upgrading LISP?
137 Views, 1 Replies
06-19-2013 04:30 AM
Quick question:
If I had some custom lisp routes that I used with ACAD 2009, then 2012...do you think I would need to upgrade, modify or change any of the lisp to work correctly in 2014?
Could a custom lisp that I used in 2012, corrupt, effect performance, screw with other key commands (although with worked in the 2012 software) in 2014 if I didn't upgrade the 2012 lisp?
And if I need to upgrade my 2012 lisps to 2014, how do I it or where can I find the answer?
Abraxas
dgorsman
Message 2 of 2 (109 Views)
Re: Upgrading LISP?
06-19-2013 07:40 AM in reply to: ParadigmAE
LISP is generally portable between versions, more so when programmed with version independance in mind.  If you are accessing Civil3D or other objects via VLA methods/properties you will likely need to make updates.  There is some command-line quirkyness in the past couple of releases which can affect user feedback during long loop operations.
Oh, and watch out for the security features - these can prevent LISPs from being loaded.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
