New Member
saraba
Message 1 of 3 (220 Views)
Updating Sheets from View Frames
220 Views, 2 Replies
12-17-2013 09:26 AM
I am using AutoCAD Civil 3d 2012.  I have succesfully created a View Frame Group (VFG) from an alignment and then created Plan Profile sheets from that View Frame group.  I did create the sheets in a seperate file from the View Frame group (that is an option when you create the sheets).  It appears that if I change a View Frame using the grips, the corresponding sheet viewport doesn't change based on the edits to the view frame.  I must manually update the sheet plan viewport to align with the edited location of the view frame.  Is there a way AutoCAD will do this automatically or does it just not do that?  Do I have to create the whole sheet set again or can I just recreate that one sheet?  I don't want to do that since create the sheet will create a new profile view.  Any suggestions?
Joe-Bouza
Message 2 of 3 (217 Views)
Re: Updating Sheets from View Frames
12-17-2013 09:42 AM in reply to: saraba
The developer intended the sheets to be drawn LAST, therefore you need to re-run
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
New Member
saraba
Message 3 of 3 (203 Views)
12-17-2013 10:34 AM in reply to: saraba
Ah, yes, I was afraid of that.  It makes sense why Autodesk wouldn't do that, but it would be a cool feature if they ever decided to add it.  Oh well, it was worth a try to ask.  Thanks
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
