Civil 3D Forum
Unpacked files in C:\Autodesk
12 REPLIES 12
Message 1 of 13
neilyj666
555 Views, 12 Replies
I've just installed IDSP 2015 via download and unpacked the files to C:\Autodesk. I only have a modest size SSD and these files files take up a lot of space (34Gb) so can I just move this folder to my secondary drive as I assume it just contains the files necessary for installation rather than actually running the programs?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
12 REPLIES 12
Message 2 of 13
AllenJessup
in reply to: neilyj666
If you need to repair the install. You will have to re-path the installation directory. I haven't done this in a few versions but It was usually just a matter of browsing to the correct directory.
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 13
wfberry
in reply to: AllenJessup
Allen:
Are you sure of this?  He is not talking about his installation location, just the unpacking files prior to installation. (I think.)
Bill
Message 4 of 13
neilyj666
in reply to: wfberry
Yes - after unpacking you get the option to save to a folder (should have done E:\Autodesk).
When the installer is run from C:\Autodesk you get the option of where to install i.e. C:\ Program Files\etc etc.
My guess is that it shouldn't matter where the files are located?
Message 5 of 13
Cadguru42
Wherever you unpack the files, if that's where you install it from then that's where all the repair functions will look to. If you unpack without installing then moving the files shouldn't cause an issue.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 6 of 13
AllenJessup
Bill,
AFAIK the software is installed from the unpacked files. If a repair or reinstall is needed those files need to be access. Note: this doe NOT apply to a Network Deployment. Only to single installation on a computer. As I said. I haven't have to do this in a number of years. But that's how I understand it. It's like copying the install from a DVD or flash drive onto your hard drive.
Allen
Allen Jessup
Message 7 of 13
Jeff_M
Allen is right. And with the Suites this is real difficult to repath everything. I helped another user with this, in the end it was easier to use the uninstall tool, move the installer folder, and reinstall.from the new location. A real PITA...
Jeff_M, also a frequent Swamper
Message 8 of 13
wfberry
in reply to: Jeff_M
OK, I stand corrected.  I really thought I remembered in the past I just deleted the whole download directory and no problem with the repair.  For now, I will just go hide in my closet.
Bill
Message 9 of 13
Jeff_M
Bill, I think that a simple repair can be done without the install files, it is a reinstall (perhaps uninstall as well?) that takes issue when it can't find the install folder(s).
Message 10 of 13
neilyj666
So presumably I'm best off uninstalling and choosing a different folder path on unpacking?
Message 11 of 13
AllenJessup
Bill,
The directory can be deleted and the software will run with no problem. If a repair is needed the files can be unpacked again. I've never tried to unpack to the same folder and run a repair. But that might very well work. I'm just not willing to test that right now.
Allen
Allen Jessup
Message 12 of 13
wfberry
Would not it be simpler if you just moved your extracted directory to another drive, then if needed move it back to square one?
Bill
Message 13 of 13
neilyj666
This is what I've done and hope that I'll always have enough room on C to move it all back if needed
Rail Community
