Thanks Jason.
Yes, I came up with a few workarounds, but the problem is now every user
that has ALWAYS just frozen a layer to keep from affecting the objects on
that layer MUST remember to do something other than what they are used to.
This is especially troublesome since the Move/Copy command reports that it
"Found X objects", with X being equal to the number actually selected, so
the user has no idea that the points are going to be affected....until it's
too late.
Jeff
"Jason Hickey" wrote in message
news:5148842@discussion.autodesk.com...
Jeff -
I tried what you did and replicated the error, and yes, it's a problem.
I don't know if it's a glitch or by design, but it's not a good idea.
The good news is that I did come up with a workaround for you - create a
new point style and call it NULL. On the display tab, turn everything
off (point label and point marker). Now, assign this point style to
your point group that you were freezing. This will control the
visibility and still allow you to move/copy linework that you've drawn
between points WITHOUT moving the points.
Hope this helps.
Jason Hickey
http://beneaththelines.blogspot.com
