Does every component need to be uninstalled individually or can it all just be uninstalled in one? If so, how do I do it?
Neil
neilyj (No connection with Autodesk other than using the products in the real world)
Sadly, one at a time.
Mike
Is there any specific order required, or recommended?
For example, years ago you could not uninstall AutoCAD and then try to uninstall Raster Design.
I don't think so. But you could do a sort by date in Add/Remove Programs and peel them off in reverse. I've never been too discriminate in my uninstalls. What gets left behind is usually manually deleted.
Mike
