I've been working this past few days on a Civil 3d 2014 file.
Today, when I finally concluded the roads and intersections, I generated the FG surface (pasting all the corridor surfaces onto a new surface) and then made a Cut&Fill surface, which I labeled with a "spot on elevation grid (@ 1m)".
After that, I had a Fatal Error close my file... and now i can't get it to open!! I've tried to open it many times but I keep getting a different "Unhandled Exception" every time, for example:
I've worked heavier files on my computer (this one is only 9.80MB), so this shouldn't be a problem.
I don't know what could be wrong here, and this problem only shows up for this particular file; I can work on any other Civil3D 2014 file I want, but not this one (which I have a due date for today!). I already tried changing the BAK file to DWG but I get the same problem.
Thanks in advance!
Alejandro Gonzalez
Civil Engineer - Costa Rica.
Solved by wfberry. Go to Solution.
I can't believe I had not tried that before... I can't be this dumb...
Thanks a lot Bill. The file is working a little too slow now, but at least I can work on it.
Thanks again.
I am having the same problem and the recover step did not help my file.....
Any new suggestions....as always Deadlines are approaching very fast
Mark Green
Working on Civil 3D in Canada
