Starting recently, upon using OPTIONS command I receive an Unhandled Exception Error. The command window pops up and I seem able to use it without issue, but this is an annoyance. (It happens in all files.) Does anyone else have this issue? I really don't want to "repair" Civil 3D 13 yet again (wow, this version seems full of bugs) but perhaps that is what I need to do...??
Repair only takes a few minutes. How long have you spent looking for a solution that would avoid using Repair?
It's frustrating, I know, but if that's the fastest solution to get you back to work...
If you keep having problems, so things to consider:
Do you notice problems crop up after you have installed another program? Possibly it is installed a system file that Civil 3D needs in a particular version, hence the errors and the ability to fix it with Repair.
or, are the errors seemingly random? Have you used MSCONFIG as a way to search for a service that might be conflicting with AutoCAD? I was having issues a while back, repair didn't help, so I did a selective startup using MSCONFIG. After some tinkering I found that iTunes was making AutoCAD crash. I eliminated iTunes and have had no problems since.
I see you're with a city gov office, so you might have to have IT do it for you. I'm sorry for that.
