Civil 3D Forum
Undo Outrage..... AND I MEAN OUTRAGED!
37 REPLIES 37
Message 1 of 38
Joe-Bouza
4967 Views, 37 Replies
I have been through SR's and have not yet received resolution to this. I have posted here and cannot figure out what is wrong, and oddly some responders do not have this issue.
How can it go on for so long?
Do I have a faulty setup through out our office? How is it my 2013/2014 undo command still does not work; hundreds of command get into the undo buffer as a result of pan zooming, making it nearly impossible to undo something.
I find it odd that this topic doesn't flood these boards to force the hand to make a patch?
If I'm way off base (let me know and I humbly apologize), and have some faulty system variable set to drive me insane please let me know. What are your settings people who don't seem to have an undo issue in 13 or 14? Why would mine be wrong installing OOTB?
What is the Name of Mike is the freakin fix for this?
Joe Bouza
37 REPLIES 37
Message 21 of 38
rkmcswain
in reply to: jmayo-EE
  jmayo wrote:
The object layers not importing is IMO the biggest pia.
Another tiny bug that could probably be fixed in 15 minutes. I wonder if this will be in the next hotfix or SP?
R.K. McSwain     | CADpanacea | on twitter
Message 22 of 38
jmayo-EE
in reply to: rkmcswain
"I wonder if this will be in the next hotfix or SP?"
Are you trying to be funny again?
John Mayo
Message 23 of 38
jmayo-EE
You must have this issue on your blog dating back what, 3 releases now?
John Mayo
Message 24 of 38
Jay_B
in reply to: Joe-Bouza
@Joe-Bouza wrote:
Not importing ambient settings makes the import tool almost useless.
Many Feature Settings and Command Settings also do not come along for the ride when using the Import Styles tool.
We had to rebuild our dwt due to an unrelated issue in our Template and started with the OOTB Acad.dwt.
Basically navigated the entire Settings Tab of Toolspace while referencing screen shots from the old dwt
 to correct & verify same settings etc.
Certainly wouldn't want to go this route with each version upgrade here.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 25 of 38
Joe-Bouza
Ok, what am I missing here?
<Snip Start reviewing settings and styles in the "new template" and several things are either missing or were ignored during the import. >
I think you answered your own question 🙂
Joe Bouza
Message 26 of 38
Joe-Bouza
in reply to: Jay_B
Thank you for confirming my angst
Joe Bouza
Message 27 of 38
Joe-Bouza
in reply to: AllenJessup
Do you start from OOTB for every upgrade and redo/import?
Joe Bouza
Message 28 of 38
rkmcswain
No, I'm genuinely serious. Really.
Message 29 of 38
AllenJessup
Joe,
Does your template name start with _A-CEA ?
Allen
Allen Jessup
CAD Manager - Designer
Message 30 of 38
Joe-Bouza
yes
Joe Bouza
Message 31 of 38
rkmcswain
It wasn't on there, but it is now. Thanks for the reminder.
Message 32 of 38
Joe-Bouza
in reply to: DMFACER
I found a block definition with the hatch in it. I overlooked for so long because the properties palette did not list any AH
Joe Bouza
Message 33 of 38
bcsurvey
Have there been any exceptions to the annotative hatch fix solution?  I'm guessing not considering that nobody in this thread history has said anything otherwise.  I'll go with it for now, but if I have the problem again and can't find any AH's, I'll come back a'squakin'!!  As happy as I'll be to be able to truly combine pan and zoom, using annotative hatches was part of my regular process from time to time.
Civil 3D 2019 (6.1)
Windows 10 Pro (21H2)
(i7-11850H @ 2.50 GHz)
32GB RAM
NVIDIA RTX A2000
Message 34 of 38
troma
I stumbled accross this blog post just the other day. I haven't tried it, but I wonder if it still works. (Dates from 2011 release.)
Mark Green
Working on Civil 3D in Canada
Message 35 of 38
Jay_B
in reply to: troma
Yes it does, we have several dwt's on our network and the only purpose they serve is to set our various PN Object Layers using that workaround.
We also use Sincpac -C3D which has an import / export object layers routine that's much faster.
C3D 2018.1
C3D 2016 SP4
Message 36 of 38
rl_jackson
So by removing annotative hatch from block solve this problem? I went through my template some time ago and looked for this in all my point blocks (symbols) and could not find a single one that had annotative hatch. I do however have some blocks that are annotative, as that I also use as point blocks.
Rick Jackson
Survey CAD Technician VI
Message 37 of 38
Joe-Bouza
in reply to: rl_jackson
I had sucess by removing the annotative hatch ( I found it in one of our structure styles). However, as I progressed with production the problem crept back. I can only assume it is do to older drawing being attached that have the hatch
Joe Bouza
Message 38 of 38
jmayo-EE
I just added HPASSOC=0 in my acaddoc.lsp file. Now to get a reminder to all users on how to use quickselect to find exisitng associative hatches...
John Mayo
Rail Community
