Civil 3D Forum
Undo File Message
3 REPLIES 3
neilyj666
224 Views, 3 Replies
Undo File Message
Been getting2013-10-28 16_04_44-AutoCAD Civil 3D 2014.jpg this message a lot today; never seen it before and no idea what it means - any clues?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
3 REPLIES 3
tcorey
in reply to: neilyj666
Are you running low on drive space? If you have Undo Control set to All, then AutoCAD is writing everything you do to a file, stored in the Temporary Drawing File Location, a setting you control through Options (Files tab.) On a default install, this is C:\Users\<<UserName>>\appdata\local\temp\.
One action that is likely to solve your issue is to close AutoCAD and then delete the contents of your Temp folder. Run AutoCAD again. Don't worry if the system can't delete some files, just bypass them.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
tcorey
in reply to: tcorey
I forgot to tell you: Be sure to turn Undo back on. Undo command, Control setting, All setting.
What that message means is that AutoCAD automatically set Undo to None, which means you have no Undo ability until you turn it back on.
Tim Corey
Redding, CA
neilyj666
in reply to: tcorey
Thanks Tim - I have 85Gb free on my SSD...I'll see if I get the message again during today...
Rail Community
