AutoCAD Civil 3D General
Active Contributor
Message 1 of 7 (894 Views)
Unable to attach DWF or FBX from Navisworks
894 Views, 6 Replies
03-02-2011 04:39 AM
I am getting an error in Civil 3d 2011 (latest patches) when I try to attach a DWF file that I created from Navisworks Manage 2011.      The error says, "DWFATTACH - Invalid File..."
Also, I exported a fbx file from Navisworks.  With fbx I do a file, import and get a similar error, "the file cannot be imported because it is an unsupported format"
You'd think autodesk products would play well together....
Product Support
Message 2 of 7 (846 Views)
Re: Unable to attach DWF or FBX from Navisworks
03-24-2011 04:45 AM in reply to: cwright
Can the DWF and FBX be opened correctly in Navisworks?
Does this happen wth all DWFs and FBXs from Navisworks?
Can you try creating a DWF and FBX from Gatehouse.NWD that should be in your Examples folder in Program Files/Autodesk/Navisworks Manage 2011 (or Simulate) and let me know if these can be brought into Civil?
What does the full error message say?
Lee Mullin
Product Support Specialist
Global Services
Autodesk Ltd.
Active Contributor
Message 3 of 7 (834 Views)
03-29-2011 11:02 AM in reply to: lee.mullin
Hey Lee,
The dwf can be opened in both Navisworks and Design review.   The error message that Civil 3D gives is:
This file cannot be opened.
The problem can be caused by sweveral things:
- The data in the files is corrupted
- The file is an earlier format that is no longer supported
-The file format is not supported.
Try to obtain a better copy of the file, recreate the file using different settings, or convert the file to a supported format.
Opened gatehouse_pub.nwd in Manage, output to dwf, and I get the same error.
I appreciate the help
Product Support
Message 4 of 7 (762 Views)
06-09-2011 03:49 AM in reply to: cwright
Sorry for the delayed response on this one.
ATTACH only applies to 2D drawings, so the 3D Navisworks DWF's will not be supported.
Lee Mullin
Global Services
Autodesk Ltd.
Valued Mentor
Message 5 of 7 (724 Views)
07-27-2011 07:58 AM in reply to: cwright
I am also getting this error message, but my DWF is a 2d DWF.  I have no idea what the original softare was that created the DWF, but when I do a save as in ADR 2012 as a DWFx or DWF and try to insert it into Civil 3D 2012 it gives me the DWFATTACH - Invalid File error.
Infrastructure Design Suite Premium 2014
Civil 3D 2014 x64
Windows 7 64-bit
6GB RAM
Distinguished Contributor
Message 6 of 7 (667 Views)
10-03-2011 08:01 AM in reply to: cwright
i just tried attaching a 3d DWF from navisworks back into regular CAD. If we an attach 3d DWG files, why not 3d DWF? :smileysad:
Product Support
Message 7 of 7 (662 Views)
10-03-2011 08:52 AM in reply to: TherealJD
The ATTACH command in AutoCAD based products inserts an external reference, raster image, or underlay (DWF, DWFx, PDF, or DGN files) in the current drawing.This has to be 2D and is usually a sheet from a DWF.
DWF's from Navisworks are never intended to be design data, just review data. A solid block in AutoCAD is handled very differently in Navisworks for performance and review reasons.
Lee Mullin
Global Services
Autodesk Ltd.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
