Civil 3D 2013
When I try to move or un-dock the command line window, a red circle with a line through it appears.
When I switch work spaces still the same result.
Any help would be great.
Solved by troma. Go to Solution.
Are your windows locked? Try holding the Ctrl key while you drag the command line.
Mark Green
Working on Civil 3D in Canada
Might look different depending on your workspace, but for me it is in the lower right corner of the main screen.
Mark Green
