I'm trying to run the following report:
UKIE - Corridor Setting Out Report - Feature Lines Points
Unfortunately I'm not getting what I'd expect.
I was hoping I can get feature lines X,Y,Z at stations using specified interval, plus all geometry stations.
As you can see from the attached files, the interval (while as expected - 10m) is not at even chainages
i.e.. 135.105 instead of either 130 or 140
This results in an empty report, as there are no stations at the odd chainages that are being reported thus no points to report.
Is there a setting I could change to get what I want? (that would be X,Y,Z,offset at CH100 110 120 etc.)
Just a quick update - when I select starting chainage 0+120, then i get a report to work somewheat - it gives me all data at 10m interva, but NOT at horizontal nor vertical change stations.
