I am currently working on a culvert drawing, using two view ports for my plan and profile sheet. As you can see below in my attachment, the UCS icon in the upper viewport is distorted, I do not how this occured nor do I know how to correct it. Would appreciate some input. Thanks
Solved by AllenJessup. Go to Solution.
With no information other than the screen shot. I would guess that your Viewtwist is not 0Ā°. Type VIEWTWIST to check. Use the DView command to reset.
It isn't a bad thing if it's not 0Ā°. Mine often isn't. That's how I make a road that isn't east to west be parallel to the boarder.
Allen Jessup
CAD Manager - Designer
Allen,
I've never Twisted a view, so I didn't know how to Un-Twist one. I just got a Hand-Me-Down drawing, molested by many hands, with a Twisted View. Thanks to you I know how to make it right.
Thanks yet again, Allen.
Dave
Dave Stoll
Las Vegas, Nevada
Dave,
My view is often twisted!
I know there are newer commands for aligning the view with the paper. But I've been doing it this way for so long I just naturally use it.
Allen
Allen Jessup
