Civil 3D Forum
Tying a feature line to a surface
47 REPLIES 47
Message 1 of 48
losfotos
1830 Views, 47 Replies
I created a label for retaining wall that takes the z value from the start and end of a feature line. Works great except that it isn't dynamic. I have created the feature line in a grading sheet where the surface is data shortcut into it and I'm just using grips to make sure the ends are on the bottom and top of the retaining wall. Is there any way to dynamically pin/tie the feature line to a surface that has been data shortcut?
Thanks!
Carl Simpson
C3D 2015 & 2016
47 REPLIES 47
Message 2 of 48
in reply to: losfotos
Its definately a work around, but you could past the data shorcut surface into a new surface and then add the feature line to the new surface.
Message 3 of 48
jmayo-EE
Instead of using grips to get the correct elevation you can use the Feature Lines Elevations From Surface command?
John Mayo
Message 4 of 48
Joe-Bouza
in reply to: jmayo-EE
Hi John 🙂
I think the op is looking to tie the geomtry in the event the wall moves horizontaly
Joe Bouza
Message 5 of 48
losfotos
Same difference really isn't it John? What I am actually looking for is a way to tie the feature line to the surface so if it moves vertically it will update without me having to do it. What I am scared about with this way of labeling is that something gets changed by one of my engineers, I don't know it's happened and a plan goes out with a bad elevation. I know this just never happens but it's my fear... 🙂 Am I just wishing against hope here?
Carl Simpson
C3D 2015 & 2016
Message 6 of 48
losfotos
in reply to: Joe-Bouza
Joe, I'm more worried about vertical moves as they aren't noticeable.
Carl Simpson
C3D 2015 & 2016
Message 7 of 48
Joe-Bouza
I misinterperted. I thought it was part of the geometry and site. The, surface elevation label is the way to go. You may even consider alignmrnt/ surface profile and alignment labels
Joe Bouza
Message 8 of 48
jmayo-EE
I think Joe hit the nail on the head with alig & prof. The profile is the only object that will get elev's automatically. With this said you create an alignment & srf profile at the bld outline. Place alignment labels that have a reference text object to extract the elv from the profile.
John Mayo
Message 9 of 48
jmayo-EE
Thought I replies to losfotos....
What's up over there on the island Joe? Keeping busy?
John Mayo
Message 10 of 48
losfotos
Hey John, thanks for the thoughts.
Doing alignments on this site is just not going to work. I have probably 60+ retaining walls on it. I'll just use the feature line and line label I think and hope and pray that my team keeps me informed of any changes (seems I'll be making the changes so it will probably be okay). Not ideal by far, but at least it isn't two separate labels.
Carl Simpson
C3D 2015 & 2016
Message 11 of 48
jmayo-EE
Yeah I know. It may be a bit easier if Alignment from Object doesn't work on Feature lines and would create multiple alignments from disconnected plines in one shot...:)
John Mayo
Message 12 of 48
losfotos
LOL, there is that. There are lots of things that 'could' be easier. But alas they aren't. Autocad is more interested in adding bells and whistles than real substance it seems. I could be wrong though. Of course if one could just pin a feature line to a surface that would make it super simple.
Carl Simpson
C3D 2015 & 2016
Message 13 of 48
jmayo-EE
Oh it's easy for all and any of us to find improvements. I was kinda hinting at a wishlist item. I think they do pretty well trying to keep all of us happy with all of our various demands. 🙂
John Mayo
Message 14 of 48
losfotos
Oh I could probably come up with a wish list.
Carl Simpson
C3D 2015 & 2016
Message 15 of 48
losfotos
Actually for a specific wishlist item: Being able to glue/tie a feature line to a data shortcut surface interactively would be nice. I've done quite a few projcts where that would have been very handy.
Carl Simpson
C3D 2015 & 2016
Message 16 of 48
jmayo-EE
I would use a FLine dynamic link to a surface everyday if we had one. A very good wish. You should post it to the Wishlist forum.
John Mayo
Message 17 of 48
losfotos
I will, thanks for your thoughts on this problem John.
Carl Simpson
C3D 2015 & 2016
Message 18 of 48
MikeEvansUK
Try civil3d reminders for a super sweet 3dpolyline to alignment & profile tool.
Think it's free too.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 19 of 48
Joe-Bouza
Now if the planimetric work is done as alignments to begin with then creating 200 retaining walls would be a breeze 🙂
Joe Bouza
Message 20 of 48
AllenJessup
I know it's a pain not having it in the core of Civil 3D. But it is available in a 3rd party program, Sincpac. I couldn't get it purchased so I bought it myself. Being able to link featurelines and points to a surface has saved my sanity on occasion. I work with an Engineer who thinks that it's perfectly OK to start "tweaking" a surface when the stakeout data needs to go out the door that day. I can edit the surface and have the elevation of the points I set for stakeout update automatically.
Allen Jessup
Allen Jessup
CAD Manager - Designer
Rail Community
