AutoCAD Civil 3D General Discussion
joeboise
Message 1 of 4 (160 Views)
Accepted Solution
Turning off minor station label display
160 Views, 3 Replies
02-07-2014 10:05 AM
Newbie here. I have an alignment drawing that I'm xrefing into a sheet drawing. The sheet drawing is an overall plan and I'd like to turn off the display of minor station labels to help readability. I've gone into Toolspace>Settings>Alignment>Label Styles>Station>Minor Station and set the label visibility to False.  The labels are still appearing though.  Any thoughts would be appreciated.
Valued Contributor
Citadel2012
Message 2 of 4 (157 Views)
Re: Turning off minor station label display
02-07-2014 10:13 AM in reply to: joeboise
You could try removing the minor station labels. Select the alignment, hit "edit alignment labels" and delete the labels.
______________________________________________________________
To Err is Human; To Really Foul Things Up Requires a Computer.
*Expert Elite*
LisaPohlmeyer
Message 3 of 4 (140 Views)
02-07-2014 11:29 AM in reply to: joeboise
I'm assuming that the alignment is labeled in the drawing that's being xreffed? Try freezing the layers that those labels are on, then label the alignment in your current drawing.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
joeboise
Message 4 of 4 (132 Views)
02-07-2014 12:44 PM in reply to: LisaPohlmeyer
Thanks! That worked.  I was thinking that label styles worked like a text style insofar as you could change the properties of them when xrefed into a separate drawing.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
