Hello everybody.
My question... what can I do to avoid the annoying mouse cursor "delay" or "jumps" when I move it inside my project ?
I have one surface and 3 aligments and this is horrible....
I have tried turn off tooltips on general options but... yes I dont see tooltips but the mouse seems to investigate the objects below the cursor....
Any help would be appreciated.
In adittion,. is there a variable to control this ? Thanks.
Civil 3D (2013) how much you have to improve....
Solved by tonnot. Go to Solution.
Do you have Selection Cycling turned on? Turn it off if it is.
Ohhh
Is the station tracker the origin of problems..... in addition I have two viewports
(That is ... the problem dissapear when I have 1 vp.=)
Any idea ?
Try and turn off as many features as possible, one at a time to see if you get better results. This could be an autosnap, or osnap issue where CAD is trying to snap to points in your surface or certain objects. Good luck!
Without doing anything special now it works fine.....
A bug ?
Sorry for your time !!!
