OK, so this is an ancient thread, but I have another question relating to this. Is this a setting you have to remember to change every time for each drawing, or can you change your defaults so that every time you save, it will be proxygraphics=1?
Change the setting in your template file, so that every new drawing will have it set correctly.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Help says "Configure the following settings in your drawing templates so that they apply consistently for all drawings created from the templates". Proxgraphics is first on the list.
So change it in your template file and all new drawings will have it set correctly. Existing drawings you'll have to change one at a time [or find/write some code to do it.
Allen Jessup
Allen Jessup
Engineering Specialist / CAD Manager
Hi Steve. That's what happens when someone comes over to talk with you in the middle composing a reply. Half an hour later the info is already stale.
Allen
Allen Jessup
