Civil 3D Forum
True representation
4 REPLIES 4
sjka
447 Views, 4 Replies
True representation
Hi there,
I have a project just completed, but I want to view it exactly how it looks, cut been taken off and fill been added. Pretty much, see the exact finished construction before it is really constructed, I have tried masking some surfaces, but doesn't seem to work.
Thanks...
4 REPLIES 4
Alfred.NESWADBA
in reply to: sjka
you can create a new surface, then you can paste existing surfaces in the order you created them. First paste the existing ground, then paste the new suface-part. Check >>>here<<< for how to paste surfaces.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Sorry, >>>this link<<< shows the paste-workflow.
- alfred -
Alfred NESWADBA
sjka
in reply to: sjka
Thanks so much,
It worked, but one more thing, is there any way I can differenciate colours, I have an existing surface, cut fill, flat area, and a road.
Alfred.NESWADBA
in reply to: sjka
as long as the surfaces are seperated you can give them different styles.
In the one that has pasted all sub-surfaces I would not know a way to do that.
Then let's think about alternative 2:
  • try to get the most outer border of all sub-surfaces.
  • create a new surface and paste the existing ground into it
  • to this new suface assign in island-border ==> the border from step 1 ==> that creates a hole in existing ground and so you see the other surfaces as seperated ones (with different styles then)
...does that work for you?
- alfred -
Alfred NESWADBA
Rail Community
