Civil 3D Forum
Trouble with double click customization
3 REPLIES 3
389 Views, 3 Replies
I have altered my CUI so when I double click on civil 3d objects it opens up their properties for quick editing. Never had a problem pre 2013 and I am sure this is something I did but am lost.
Every time I double click on any object it just opens up the properties box. It skips right over my double click customization.
Thanks in advance.
Regards
Rob
3 REPLIES 3
BrianHailey
Which CUI file are you editing? Is it possible that another CUI file has the double click action set to the AutoCAD properties?
Just thinking out loud here.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
in reply to: BrianHailey
Good day Brian,
It is the Civil CUI that I am editing. It was working just a couple of weeks ago but now all I get is the properties box when I double click on any object that has double click functionality assigned. Needless to say this is very frustrating.
machadt
Hi Rob,
Please make sure that Object Name under Advanced Properties for the double click action is set to the particular object type associated with the command that you are trying to use, as this image shows.
You can find this information if you do LIST.
Tatiana Machado
AEC-ENI Application Engineer
Rail Community
