Hi!
I are working on a corridor with a lot of targets and the attached section. But at some sections it messes up! Any ideas?
See attachment.
Edited by
Discussion_Admin
Solved by martin_sabel. Go to Solution.
The corridor should be straight and follow the target lines (the purple and magenta ones) but instead jumps in a strange way between different lanes. It does this in several places. I have a lane set to zero width that widens to create a parking space by targeting the purple lines. I have an idea that those are the problem but can’t figure out a solution.
And sorry for bad English, I am from Sweden...
You need to see what exactly is different at the locations where it does this vs working fine. While I can see what you've identified as the problem, there's not enough info here to really troubleshoot.
Also, are you using stock sub-assemblies or sub-assemblies created in SAC? What version are you using?
Don Ireland
Engineering Design Technician
Autocad Civil 3D 2012
sub-assemblies
Testing to attach the file to dropbox, a download link below.
https://dl.dropboxusercontent.com/u/17985531/%23M10-P100%20-%20Martins.dwg
Checking the locations where it does this vs working fine...
Thanks for the quick respons!
And the targets for the korridor "Nolhagaleden" is on the layer "KORRIDOR Nolhaga Targets" and "KORRIDOR Nolhaga Targets 2". Targets 2 is for the parking targetlines which i think is the problem. Maybe it is because the lines in Targets and Targets 2 is in conflict? Se attachment...
I increased the frequency and changed the target lines so that they no longer went in parallel with the others. It seemed to solve the problem somewhat, or at least minimize the impact.
