Civil 3D Forum
Trouble with EXPLODE and MOVE
12 REPLIES 12
Message 1 of 13
neilyj666
431 Views, 12 Replies
Last week I could select objects and EXPLODE or MOVE but today I select objects and they get deselected when trying EXPLODE and MOVE.
The PICKFIRST variable is set to 1 so I'm at a loss to think of what has changed - any ideas?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
12 REPLIES 12
Message 2 of 13
neilyj666
in reply to: neilyj666
and the HATCH options only seem to be available on the command line
Message 3 of 13
hmartinez5
Is it only that drawing or is it your ACAD installation?
Message 4 of 13
neilyj666
in reply to: hmartinez5
MOVE and EXPLODE (not tried any other commands) work as expected when using vanilla AutoCAD 2014 from IDSP but not when using Civil 3D 2014 or Civil 3D 2014 as AutoCAD...possible corrupt profile?
Message 5 of 13
jmayo-EE
pickadd = 2?
John Mayo
Message 6 of 13
hmartinez5
It is probably the drawing. If possible export from vanilla ACAD and reopen with Civil.
Message 7 of 13
neilyj666
in reply to: jmayo-EE
Yes it's set in my acaddoc.lsp to be 2
Message 8 of 13
neilyj666
... after they have been deselected, I can type P at the Select Objects prompt and continue with the command as expected.
This behaviour is very annoying....Smiley Mad so am grateful for any further suggestions...Smiley Happy
Message 9 of 13
troma
QAFLAGS to 0 (zero)?
Mark Green
Working on Civil 3D in Canada
Message 10 of 13
neilyj666
in reply to: troma
Good call - never heard of that variable before but it was set to 1 and resetting to zero seems to have solved the problem; it's now in my acaddoc.lsp file...:)
Message 11 of 13
troma
Apparently it's undocumented, but used in lisp for I forget what. Possibly you had a lisp command cancel half-way through and leave it like that? Or some badly written lisp?
Mark Green
Message 12 of 13
neilyj666
in reply to: troma
Yes it was a lsp that was here http://autodesk.blogs.com/between_the_lines/2013/10/happy-halloween-autocad-and-civil-3d-trick-or-tr... - the Civil 3D lsp reset my QAFLAGS but didn't reset it.....
Message 13 of 13
jmayo-EE
Never heard of that one either.
Good call there Troma.
John Mayo
Rail Community
