Last week I could select objects and EXPLODE or MOVE but today I select objects and they get deselected when trying EXPLODE and MOVE.
The PICKFIRST variable is set to 1 so I'm at a loss to think of what has changed - any ideas?
Solved by troma. Go to Solution.
... after they have been deselected, I can type P at the Select Objects prompt and continue with the command as expected.
This behaviour is very annoying.... so am grateful for any further suggestions...
Mark Green
Working on Civil 3D in Canada
