I'm brand new to Civil 3D. Working on personal project and I did my own surveying of a slope. I'm trying to import a .csv file as Points From File. Just can't get it to work. I tried columns of PNEZ, NEZ, PNE (changing both the csv file and the import style); tried making all values the same number of digits and decimal points. Nothing works. Usually it says "Does not match selected point file" but sometimes it says "No point file match found" but sometimes it wil allow an import but then nothing appears in the drawing file.
Is there some special formatting I need to do to the CSV file in order to get it to import? Or am I missing something else?
I've watched half a dozen tutorials on creating surfaces (which is all I really need to do) and also tried manually creating points. I can create the points, but I can't get them to convert into a surface. Any pointers on how to create a surface would be appreciated. It's just my backyard, so it's not a complicated project.
I was able to import your file.
Insert Tab of Ribbon>Points From File>Specify Format>PNEZ (space delimited)>Click Plus button upper right>Change file type filter to csv and import point file.
Zoom Extents after importing.
Once points are imported if I attempt to re-import I also get the message: "No point file match found"
Note: If there's a black dot to left of "Points" on Prospector tab of Toolspace then you have something else going on.
The black dot indicates points present in dwg which could be styles used etc.
My guess is they are importing and not displaying.
Thanks. Following your steps it does seem to import. This time, it displays one large X that fills the screen when I zoom extents. And yes there is a black dot next to Points. As soon as I click on the large red x -- Civil 3d crashes. Any idea what the large red x means?
The large X sounds like you are using a basic point style that displays an X so large that all of the points look coincident at the scale Zoom Extents takes you to. I'm not sure why you got the crash.
Allen
Allen Jessup
CAD Manager - Designer
What version do you have?
There's something odd in your csv file. I opened the PNEZ (comma delimited) format in the properties editor and loaded your file in order to run a parse test on it. It appears that the file is missing the proper CR/LF characters which should separate the lines of data.
I opened the file in Excel and resaved it, making sure to use this .csv option - not the older ones. After that I was able to load the file correctly.
I'm having a similar issue.
After creating a point file format and clicking Parse, the data looks to be delineated properly.
While in the 'Import Point' dialogue, the second box says 'Specify point file format'. With the filter on, it doesn't give me the format the data is in. When I select my file, it gladly delineates in using incorrect columns. When I turn off the filter and select the format I'm using, a warning shows up on the 'Selected Files' section and the status says 'Does not match selected point file.'
If you use Notepad for these points, there is no formatting to worry about. Just use a .txt file. If you WANT a .csv file, just rename the suffix.
Bill
please am a new with auto cad civil 3d, i read other people' comment about having difficulty in importing their data. i have a similer challenge too. please kindly provide any assistance you can with my data. i have attached my excel( csv) data.
thanks.
There are many points that have no coordinates in the file. You either have to determine why they don't have coordinates and create them or delete those lines from the file. Then import as a Comma Delimited File.
Allen
Allen Jessup
Agree with Allen, unless you ignore the missing data, obtaining the attached shapefile...
Also. Are the elevations actually near zero or did you get a point file with a delta Z field.
Allen
Allen Jessup
The elevations seem to go from 0.2 to 5.2 units, plausible in a flat terrain...
Yes. Plausible. But I thought it was worth asking. There are negatives in the lines with no coordinates. I could think up some reasons for that but can't be sure without the OP's input.
Allen
Allen Jessup
Can you expand on a few things. By "controller" do you mean your Data Collector or something else? Does "sft" refer to Survey Feet or Sq. Ft. (I believe the former but like to check).
Since the measurements are an order of magnitude apart. Can you tell us which one you believe to be correct?
Can you share the point file and/or the drawing? A step by step description of how your importing the .csv file with a few screenshots would go a long way in helping diagnose the problem.
Allen Jessup
