Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
Did you mean:Ā
Trouble Creating a TIN from a point cloud.
5 REPLIES 5
881 Views, 5 Replies
Hi all,
I have been searching for a solution to a problem i have been having. I have a point cloud, and I am wanting to TIN it to create a surface.
When I use the Create Surface tool, no dialog box appears. Everything I have found seems to rely on this Dialog Box. Any ideas on how to get it to display?
Using AutoCad Civil 3D 2011.
5 REPLIES 5
antoniovinci
After you've made a new database with the _CREATEPOINTCLOUD command, issue the _ADDPOINTSTOSURFACE command in order to create a 3D surface.
The create surface from points is under the point cloud menu, not the surface menu  - not very intuitive.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
I'll give that a go.
in reply to: ericcollins6932
I have my .LAS file as a point cloud and when I go to create my surface from my selected size of point cloud, in the final window of the process, it says that there are 0 points to be added to the surface.  How can that be?
ericcollins6932
Do you have the ground points displayed? If all the points are off, it won't do anything.
Win 10
16 GB RAM
Civil 3D 2019
Rail Community
Ā
Ā
