AutoCAD Civil 3D General
*Expert Elite*
Jeff_M
Message 11 of 20 (571 Views)
Re: Trimble Feature Codes -> Desckeys
12-29-2011 12:05 PM in reply to: derek.gray
Got them, thanks! Now I'll see what I can come up with over the weekend.
*Expert Elite*
Jeff_M
Message 12 of 20 (550 Views)
01-01-2012 03:48 PM in reply to: Jeff_M
Well, this is what I've come up with.....
It shows all of the Layers, Blocks, and PointStyles defined in the Trimble FXL. You can add a prefixe to any of these, as shown. Selecting OK the creates a new DescriptionKeySet using the name provided in this form.
This is the result:
The Scale settings do not get imported, as I couldn't determine what they were supposed to be doing, so I just assigned all of the PointStyles to "Use drawing scale".
I you are interested in obtaining this, please shoot me a PM.
*Expert Elite*
Neilw
Message 13 of 20 (546 Views)
01-01-2012 06:16 PM in reply to: Jeff_M
I don't have TGO in front of me so I can't run any tests but you can import a CSV into ACCESS. Is there some reason why you can't make that  work?
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
*Expert Elite*
Jeff_M
Message 14 of 20 (541 Views)
01-01-2012 07:02 PM in reply to: Neilw
Based on the first post, he can't save to Access97. Based on the CSV file he posted, it doesn't output the required information.
Member
Message 15 of 20 (399 Views)
12-10-2012 09:30 AM in reply to: Jeff_M
This would be benifical to us the use of the Trimble feature codes import, would you be able to explain how i can achiecve this?
Member
Message 16 of 20 (397 Views)
12-10-2012 09:31 AM in reply to: Jeff_M
Jeff,
are you able to explain ho wyou got that pop-up window to appear? we have recently invested in Civil CAD 3d and this would be helpful.
Regards
Andrew
*Expert Elite*
Jeff_M
Message 17 of 20 (390 Views)
12-10-2012 09:59 AM in reply to: adobrucki
Yes, this is something I programmed to do using C#. It is currnetly one of the many commands available in the SincpacC3D.
Member
Message 18 of 20 (370 Views)
12-11-2012 01:15 AM in reply to: Jeff_M
Jeff_M, so its a add-on not something that can be easily doen wiothout purchasing the software Sincpac?
*Expert Elite*
Jeff_M
Message 19 of 20 (360 Views)
12-11-2012 10:02 AM in reply to: adobrucki
That's correct. It took me about 5 days to program. It will try to create all symbols and styles to match what is specified in the fxl file. You are more than welcome to test it out, as there is a 28 day free trial availble which includes full functionality of all commands.
Valued Contributor
Message 20 of 20 (353 Views)
12-11-2012 11:33 AM in reply to: Jeff_M
Jeff, thanks for tackling my problem. I have downloaded it to play with...
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
