AutoCAD Civil 3D General
Valued Contributor
Message 1 of 20 (1,955 Views)
Trimble Feature Codes -> Desckeys
1955 Views, 19 Replies
12-23-2011 12:23 PM
We have our Trimble TSC3 setup and working nicely to collect field data using Trimbles feature codes... question is, is there a way to import/convert these feature codes into DescKeys... I'm working on a convoluted way but in the end I don't think it will work because I can't save it to Access-97 format... Is there an easy way or am I doomed... Thanks_DRG
Valued Contributor
Message 2 of 20 (1,951 Views)
Re: Trimble Feature Codes -> Desckeys
12-23-2011 01:10 PM in reply to: derek.gray
working in Civil3d2012 SP1
Windows 7 64-bit
Jeff_M
Message 3 of 20 (1,945 Views)
12-23-2011 02:32 PM in reply to: derek.gray
I don't have anything Trimble to know what format(s) it can save to. Can you export the keys to XML or plain text file? Can you post a small example of either one, or both?
Valued Contributor
Message 4 of 20 (1,942 Views)
12-23-2011 02:58 PM in reply to: Jeff_M
I will put together what ive found and post back after the holiday... thanks for the reply and Merry Christmas...
Valued Contributor
Message 5 of 20 (1,905 Views)
12-29-2011 07:04 AM in reply to: derek.gray
In the Trimble Feature Editor the available file types to export to are: see attached clip.
Unfortunatly the export to .csv doesn't seem to collect all the information. If it would I think I could put the list together, but I would still have to find a way to save-as access97... Thanks
--Sorry for the delay I've been out sick--
Jeff_M
Message 6 of 20 (1,896 Views)
12-29-2011 08:03 AM in reply to: derek.gray
Why does it need to be saved as an MDB? (Access97)
If you can, would you post a small example fxl file along with a csv created from that file?
I'm asking for these because I think it will be possible to write a progarm to import them directly to C3D...but without knowing what these files look like I can't investigate any further. I've searched Google for sample files, with no luck.
Valued Contributor
Message 7 of 20 (1,889 Views)
12-29-2011 08:34 AM in reply to: Jeff_M
Jeff, the page gives me the following error when i attach the .fxl file and try to post it...
Please correct the highlighted errors and try again.
  • The file does not have a valid extension for an attachment. doc,pdf,dwf,dwg,dxf,dst,gz,gzip,zip,bm,bmp,gif,jfif,jpe,jpeg,jpg,psd,tif,tiff,png,htm,html,xml,xls,lsp,svf,3ds,vcf,png,text,txt,log,env,dcl,rvt,rfa,ipt,iam,ipn,dwfx,idw,csv,nwf,nwc,nwd,sdf are the valid extensions.
Valued Contributor
Message 8 of 20 (1,886 Views)
12-29-2011 08:37 AM in reply to: derek.gray
I would be happy to email them to you or if you have another way let me know... Thanks
Jeff_M
Message 9 of 20 (1,883 Views)
12-29-2011 08:42 AM in reply to: derek.gray
Either add it to a zip file or just rename it and add a ".txt" to the end. Then it will post here just fine, as long as it is < 1.5mb
Valued Contributor
Message 10 of 20 (1,881 Views)
12-29-2011 08:47 AM in reply to: Jeff_M
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
