We have collected points with our new Trimble unit. We have downloaded, converted and translated to Nad 83 PNEZD file using Trimble software.This coordinate system was chosen because the "HARN" coordinate system is not available in the conversion software for the Trimble. The work around was to import points to a drawing set to LA83-SF-MOD coordinates. The project I need these points in is setup in LAHP-SF which is HARN(HPGN) Louisiana State Planes, South Zone, US Foot. I should easily be able to Query this point drawing into my HARN drawing. No cigar.
Attached is my error message. Any ideas????
Map queries don't work on C3D objects.
Why don't you just bring them into the drawing directly from the point file? Create a point file format with the coordinate system of the point file and import them into the drawing with the desired coordinate system and it will do the conversion for you. Just make sure you toggle on "Do coordinate transformation if possible".
Thats a great idea but it doesn't work. What we have done is create an Autocad drawing with the HARN coordinate system. We exported our points from the Trimble sotware as Shape files (*.shp). Shape files have projection files associated so we imported the shape files into our new HARN drawing as Autocad points. We then xrefed the new HARN drawing into the HARN base drawing. Bind it. Explode it. Points-Utilities-Convert Autocad points to Cogo Points. Lost my descriptors but way past caring.
Finally convinced the males here to call the Trimble consultant. Coordinate system NAD83(conus)cors 96 is within a few centimeters of HARN. So for now I think this is solved. If it isnt I will be back.
And thanks for the heads up about query and C3D. Never thought about it.
It should have worked. Did you create the new point file format with the correct coordinate system? It will preserve your descriptions.
Made a new call to the Trimble rep. Discussed translation procedures. We were using Imperial Foot instead of Survey Foot. Now our imported point files match the shape file generated Autocad points. Think we got it. Thanks. I love our new toy.
After printing out your attached file I have investigated what you posted. So now I think I get what you were trying to explain. This editing of the PNEZD should be attaching a projection description to the points I am importing and translating them to the HARN coordinate settings in the actual drawing??? Not working. Is it possible that there is a Command setting that is preventing the translation? Thanks
