Civil 3D Forum
Trim *.sdf file
2 REPLIES 2
273 Views, 2 Replies
Trim *.sdf file
The topo *.sdf file I brought into my drawing covers much more area than I
need. How do I trim it to a smaller area?
2 REPLIES 2
How did you bring it in? If you used Mapimport then use the map boundry trim
command or cookie cutter in the xpress tools. If you used data connect right
click on the SDF layer in maps display manager and query by filter and
select locateon map in the create query dialog.
Murph
http://map3d.wordpress.com
___________________
"Joe McManemin" wrote in message
news:6341524@discussion.autodesk.com...
I usewd Data Connect. When I query by filter - select location, the entire
sdf data disappears.
"Murph" wrote in message
news:6341925@discussion.autodesk.com...
Murph
___________________
Rail Community
