Civil 3D Forum
Trim 3D newbie! help!
2 REPLIES 2
670 Views, 2 Replies
Hi! i'm a Autocad 3D newbie! Have some problems to figure out how to trim a solid from a sphere. well here's an image that will explain better!( it's the pink part from the green)
thank you so much !
Tags (3)
2 REPLIES 2
jmayo-EE
You would probably get better help with AutoCAD 3D solids on the AutoCAD message boards.
Did you use the Subtract command on the objects? If not this look at the Union command and the other solid edit command on the ribbon panel shown.
John Mayo
in reply to: jmayo-EE
the subtract command subtracts the whole pink solid and leaves the empty shape in the sphere, I just need to cut the part that sticks out from the bottom of the sphere!
no luck with union either
but thanks! trying on autocad 3d solids!
Rail Community
