AutoCAD Civil 3D General
Distinguished Mentor
Message 1 of 4 (248 Views)
Tree Point Table
248 Views, 3 Replies
12-01-2012 09:22 AM
How would I create a Point Table that would allow me to have Point#, Type, Size in individual columns when I have decription keys that area like this;
GUM 6  to be a 6" GUM.
Is there any way to have the data for the Type in one colum and the size in another?
Is there a possible work around that anyone can think of?
TIA
C3D12
C3D12-13
Win7x64 6gb
BrianHailey
Message 2 of 4 (239 Views)
Re: Tree Point Table
12-01-2012 12:50 PM in reply to: rl_jackson
Description keys only work on descriptions. You can use the description keys to assign the appropriate style to the points (assuming the description is GUM) but you wouldn't be able to use the "6" to scale your point symbol with it in a different column. If you don't need to use the "6" for anything but labeling purposes, you can use "User Defined Properties" and create a new property for you point for the size column and then use that in a label style.
Message 3 of 4 (221 Views)
12-02-2012 06:09 AM in reply to: BrianHailey
Looks like udp will do the trick, just going to take some doing to implement it.
C3D12-13
Win7x64 6gb
*Pro
Message 4 of 4 (159 Views)
01-09-2013 12:01 PM in reply to: rl_jackson
in our raw descriptions we code our trees similar to gum 6 and using the codes for full descriptions we can transform it to read 6" gum.   We also use part of the description to size our tree symbols.
first off to break down gum 6 into the codes needed to transform them into 6" gum.
the first part of the descriptoin is $0  or gum.   the next part is $1 or 6.   to in your full description column you would write it as $1" $0 or 6" gum.
as for scaling the symbol by a part of the description the $1 that represents the size or 6 is addressed under the scale parameter column.   used parameter 1 and make sure it is checked.    We here at Prein&Newhof did not want to scale our tree block by 6 times or 52 times for a big tree so we came up with a more reasonable scaling factor and used a net program to covert all tree scaling before the fbk was written.   a 10 inch tree might have a scale parameter of like 1 whereas a 20 inch tree would be 2 etc...
I hope this helps.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
