Civil 3D Forum
Transparent Commands
21 REPLIES 21
Message 1 of 22
1157 Views, 21 Replies
Is anybody having problems when using the transparent commands in Civil 3D 2015. When I enter a bearing using a command and then check it with the list command it is different. I wasnt having this problem in 2014.
21 REPLIES 21
Message 2 of 22
Jay_B
Autocad UNITS command? - Is it possible that the Angle type is set to something other than "Surveyors Units"?
If this doesn't help please provide more details on the differences you're seeing between input & listing.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 22
in reply to: Jay_B
Hi, Jay_B, I did check my drawing units and have them set on "Survey Units". When I draw a line and  type in my command say quadrent 3 at 6.5432  at 100.00 using the transparent command "Bearing Distance" and then list that line it gives me say S 05d30'30" w.at 100.00'.
Message 4 of 22
Jay_B
Interesting, I don't have access to 2015.
Have you compared the Ambient Settings for the "Direction" Property between 2014 & 2015 versions to
see if there are any diferences in settings?
C3D 2018.1
C3D 2016 SP4
Message 5 of 22
Pointdump
T,
Post a drawing where you have that problem. Even if you just put one line in a new drawing.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 6 of 22
in reply to: Jay_B
The Ambient settings for "Direction" between the two versions seem to be the same.
Message 7 of 22
Jay_B
Is UCS set to World in both files?
C3D 2018.1
C3D 2016 SP4
Message 8 of 22
Pointdump
T,
"...quadrent 3 at 6.5432 at 100.00 using the transparent command 'Bearing Distance'..."
I drew same and got same in 2015.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 22
in reply to: Jay_B
Yes
Message 10 of 22
in reply to: Pointdump
Here is a drawing where I drew a line using the transparent command "Bearing Distance" I entered 3 for the quaderent and 0.26422 for the bearing and a 100 for the distance. When I list this line it is  S0d15'51"W at 100'
Message 11 of 22
Pointdump
T,
Curious. I labeled your line on the left and then I drew and labeled the line on the right. Seems to work OK. Dunno. I noticed your Ambient Settings are Decimal, and yet the line labels in DMS.
Dave
Dave Stoll
Las Vegas, Nevada
Message 12 of 22
I noticed that in 2015 if you enter the bearing as 0d26'42" vs just putting the numerical number 0.2642 it will draw the line correctly. You didnt have to do that in 2014. Is that how you are entering the bearing?
Message 13 of 22
Pointdump
T,
I entered it thusly: 3, 0.26422, 100
Dave
Dave Stoll
Las Vegas, Nevada
Message 14 of 22
Jay_B
Please verify is the ANGBASE system variable set to zero?
C3D 2018.1
C3D 2016 SP4
Message 15 of 22
in reply to: Jay_B
Check
Message 16 of 22
Edit drawing setting \ Ambient Settings \ Angle
Message 17 of 22
Didn't work but thank you.
Message 18 of 22
wfberry
King:
Type the command:  AECDWGUNITSSETUP
I suspect you will see your problem.  Notice that SURVEYORS is listed as the angle type.  This is a NO NO
Set it to Decimal Degrees.
Bill
You also have the drawing set to INTERNATIONAL FEET.   Is this what you want?
Message 19 of 22
Pointdump
in reply to: wfberry
Bill,
From the Help Section:
"Surveyor's units: N or S for north or south bearings, degrees/minutes/seconds for how far east or west the angle is from direct north or south, and E or W for east or west; for example, N 45d0'0" E. The angle is always less than 90 degrees and is displayed in the degrees/minutes/seconds format. If the angle is precisely north, south, east, or west, only the single letter representing the compass point is displayed."
That is exactly the angle format that anyone working with bearings needs. I'm curious why that's a No No. Can you elaborate? I opened up T's drawing with 2015, and I was unable to duplicate the problem he's having. It might be a System Variable somewhere.
On this Forum I once read that changing any of the ACAD drawing units was a No No, and that you should only change units in the Drawing Settings. I think it was Sinc that said it.
Dave
Dave Stoll
Las Vegas, Nevada
Message 20 of 22
rl_jackson
your settings are reading the 26422 as decimal degrees not dms
Rick Jackson
Survey CAD Technician VI
Rail Community
