All of our jobs are tied to State Plane and when we need to have the survey data in its original bearing set we use the transformation tab. Not only do we rotate, but we move it to a 5000, 5000 coordinate set to make the transformation obvious.
Our dilemma is that we bring in GIS data (mainly shape files) through map. How can we get this GIS data to do the same? I have searched the posts and the outlook seems bleak. I hoping there is a somewhat simple way.
We are using C3D2011.
Solved by Sinc. Go to Solution.
You are correct... The Transformation Tab is disconnected from all MAP functionality, so there's no way to automatically transform data from other coordinate systems when you are using the Transformation Tab.
