I had created a drainage structure and pipe table to match a local municipalities requirements and it uses several expressions to populate the desired data. I have tried style import and wblocking out the table to no success. Import styles doesn't list table styles and wblocking does not carry over the expressions. is there a way? I guess I could copy the file delete and purge everything an insert as a last resort.
Joe Bouza
This is a C3D table? Did you try to drag and drop the pipe expression & table style? The expressions are in the pipe or structure tree not the table tree.
John Mayo
Joe Bouza
Joe Bouza
good luck
Joe Bouza
Joe Bouza
