Civil 3D Forum
Toolspace tabs disappear when I hit plot
3 REPLIES 3
427 Views, 3 Replies
When I hit the plot button my Toolspace tabs disappear. I am running AutoCAD C3D 2011. Can anyone help me?
3 REPLIES 3
andrewpuller3811
I get the same issue, never noticed before that it was the plot command.
It occurs specifically when the toolspace is closed to generate the plots, either when showing a plot preview or prior to sending to the plot device.
I have raised this with autodesk with the fact that is caused by the plot command. Hopefully they might find a solution now.
Only way to egt them back is click twice on the toolspace button. Once to close the toolspace, and again to open it.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
troma
in reply to: andrewpuller3811
I believe this is a know issue.  Anyone got an answer yet?
My workaround is to plot without doing a preview, but this is not always an option.
Mark Green
Working on Civil 3D in Canada
AlmasSuljevic
It is a known issue. You can just click on Toolspace icon in Home ribon and taht would load the missing tabs.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Rail Community
