Member
tjhootman
Message 1 of 16 (2,005 Views)
Toolspace Item View not working properly
2005 Views, 15 Replies
07-20-2012 12:23 PM
I'm having trouble viewing a list within Toolspace Item View. When I click the item in the tree nothing shows up in the item view. There should be a list of all my parcels but there is not. Graphical view works fine. List view works fine with other items in my tree except for my parcels. Also, when i right click parcels and click refresh I can see the list genereate in item view but then it quickly disappears. Any ideas what is going on?
wfberry
Message 2 of 16 (1,998 Views)
Re: Toolspace Item View not working properly
07-20-2012 12:56 PM in reply to: tjhootman
Try changing the Top Row "Active Drawing Name" to Master View.
Bill
wfberry
Message 3 of 16 (1,997 Views)
07-20-2012 12:57 PM in reply to: wfberry
Errr Active Drawing VIEW
Billl
Member
tjhootman
Message 4 of 16 (1,995 Views)
07-20-2012 01:10 PM in reply to: wfberry
I've tried both. Nothing has worked. It's very odd. Everything displays fine in item view except for my parcels list. When I click individual parcels in the tree the graphical view displays properly. When I click other items such as points or surfaces they display as a list. I know the information is there because I can see it for a brief second when I click refresh parcels. It just disappears and I can't get it to display again. I've even reinistalled the software and gotten the same result. I'm trying to edit the parcel styles of mutiple parcels. Is there any other way to view a list of all my parcels and edit them in bulk other than in toolspace?
Jeff_M
Message 5 of 16 (1,991 Views)
07-20-2012 01:46 PM in reply to: tjhootman
What version of C3D and which Service packs have been applied?
Jeff_M
Message 6 of 16 (1,990 Views)
07-20-2012 01:50 PM in reply to: tjhootman
One way is to select one of the parcels in the drawing that you want to change the style of, right-click and choose Select Similar. This should select all of the parcels using that style. If you need to remove some, do so be normel slection removal, then use the Properties Manager to change the style.
Member
tjhootman
Message 7 of 16 (1,988 Views)
07-20-2012 01:56 PM in reply to: Jeff_M
I am using Civil 3D 2013. No service packs have been applied. Thanks Jeff. I will use the 'select similar' as a workaround but I'm still curious as to why it's not displaying properly in item view.
rkmcswain
Message 8 of 16 (1,844 Views)
11-13-2012 11:36 AM in reply to: tjhootman
rkmcswain
Message 9 of 16 (1,836 Views)
11-13-2012 12:28 PM in reply to: tjhootman
Ok, that was pretty easy to fix.
Open REGEDIT
Go to:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-Bxxx:xxx\Profiles\<<your_profile_name>>\Dialogs\AxUiMgrItem
Then look in the right pane for a AeccMgrParcel:List:AeccMgrPltProspector:smileytongue:rospector
Click on it, press F2 to enter rename mode, give it a new name like "X"
Go back to C3D, and try again.
C3D will recreate the binary data with the correct values.
Close REGEDIT.
Do not try to sort again!
mathewk
Message 10 of 16 (1,425 Views)
01-08-2013 02:09 PM in reply to: rkmcswain
This fix is great, but still a bit of a pain.  i have created a LISP routine you can run that fixes this.  See attached.
This command is FIX.
When the bug happens, run this command, click to somewhere else in the prospector then click on Parcels again and you should see the populated list.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
