Civil 3D Forum
Toolbars fail to resize
9 REPLIES 9
Message 1 of 10
randcdavidson
1569 Views, 9 Replies
Windows 7. AutoCAD Civil3D r13 and 14.
Yes the toolbars are unlocked and even when they are locked using the ctrl key still will not alow me to resize. This used to work but now for some reason will not anymore. Any ideas as to why?
9 REPLIES 9
Message 2 of 10
tcorey
in reply to: randcdavidson
Have you tried it with a different profile current?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 10
randcdavidson
in reply to: tcorey
Yes tried different profile. I can resize the propspector and properties windows but any floating toolbar like the dimension I can't. When I say resize I mean stack from a single row of icons to a double or triple.
Message 4 of 10
lim.wendy
 Hi there,
The toolbar seemed to reset to its original size if you use the existing / default toolbar.
Try creating a duplicate of the toolbar and resize. It seemed to work.
See video:
http://www.screencast.com/t/LQj79VyfX9o
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Message 5 of 10
Jeff_M
C3D2014 - I can resize the Dimension toolbar just fine. Although the sizing arrows are quite small and tricky to click at the right time.
Jeff_M, also a frequent Swamper
Message 6 of 10
Yes my co-worker can stack his too. Mine will not for some odd reason. I can see the outline of what the resulting stack would look like when draggin the corner but don't get the desired result.
Message 7 of 10
randcdavidson
in reply to: lim.wendy
Lim I tried the duplicate thing too. Still will not work. This is going on in both 2013 and 2014 C3D.
Message 8 of 10
lim.wendy
Can you try to load the cui attached to this post?
That will give a clue whether there's something amiss with your C3D.
If should load like the one in my video. Else, I'd suggest initiating a secondary installer
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21789329&linkID=9240697
Smiley Happy
Wendy Lim
Customer Value Hub
Message 9 of 10
troma
Do you have your toolbar inside the drawing space or outside the extents of the program? I found that I couldn't stack my toolbars when they were on my second monitor. I dragged them into the drawing space, stacked them, and dragged them back onto the second monitor: worked fine that way.
Mark Green
Working on Civil 3D in Canada
Message 10 of 10
chomuth
in reply to: troma
Thank you that worked perfect.
How crazy that it doesn't stack on the second monitor
Rail Community
