coloeng
Message 1 of 5 (2,717 Views)
Tool Palette - Blocks won't insert
2717 Views, 4 Replies
03-22-2012 08:08 AM
I am working with a client who has a standard tool pallete with blocks. I already have imported/customized the tool palletes as per their manual. The blocks show up in the tool paleltte, but when i drag to insert them. It can't locate the symbols file and gives me this error : Source drawing "H:\MASTER-SYMBOLS.dwg for block "X" not found.
I have the master symbols drawing as indicated and pathed the location through options\files\tool palletes file locations
so not sure what im doing wrong or if it needs to be pathed somewhere else.
Thanks!
BrianHailey
Message 2 of 5 (2,705 Views)
Re: Tool Palette - Blocks won't insert
03-22-2012 09:16 AM in reply to: coloeng
The original drawing that the block tools were created in has been moved or it's name has been changed. The options path for toolpalettes tells AutoCAD where to find the tool palettes, not the files that the tool palettes reference. Right click on the block in the TP and select Properties. This will tell you where the tool is looking to find the block. Either change the tool to look at the new location or move the original drawing back to that location.
coloeng
Message 3 of 5 (2,695 Views)
03-22-2012 11:07 AM in reply to: BrianHailey
That worked! but i have about 200 blocks. is there a way to change that setting globally?
coloeng
Message 4 of 5 (2,684 Views)
03-22-2012 11:24 AM in reply to: coloeng
ok. i think i figured it out. just highlight all the blocks in the pallete and click properties.
thanks for the help!
Member
dikesh
Message 5 of 5 (1,307 Views)
09-05-2013 01:35 AM in reply to: coloeng
when i select all the block and browse the source file, it won't allow me to select the folder and all the blocks are not in one dwg file. Pls help.
Regards
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
