AutoCAD Civil 3D General
Distinguished Contributor
CrazyIvan
Message 1 of 5 (93 Views)
Toggline Corridors in an XREF'd Drawing
93 Views, 4 Replies
06-19-2013 09:30 AM
Is there a way to toggle visibility of a corridor in a drawing where the model has been Xref'd into?
The problem I am having is that we have one Model drawing that has a corridor.
This Model is xref'd into multiple drawings.  Not all drawings should show the corridor.
The only way I have found so far is to go into model and toggle the corridor on and off depending on which drawing I want to print or view.  It creates problems when you want to run a Publish of multiple drawings because you always have to goof with the Model file.  This seems a bit of a step back from being able to toggle visibility of objects in a drawing file with an xref atached and leaving it that way and ready to be printed at any time.
Thanks.
*Expert Elite*
Jay_B
Message 2 of 5 (90 Views)
Re: Toggline Corridors in an XREF'd Drawing
06-19-2013 09:43 AM in reply to: CrazyIvan
In the corridor object style the layers can be set to something such as C-Road-Corr and then can be frozen in drawings as desired assuming the xref is attached on layer zero and Visretain is set to 1 in the dwg's referencing corridor source dwg.
Jay
C3D 2014 SP1
Win 7 Professional 64 Bit
*Expert Elite*
LisaPohlmeyer
Message 3 of 5 (80 Views)
06-19-2013 10:46 AM in reply to: CrazyIvan
My workflow is exactly like Jay's.  We have our corridor object mapped to it's own layer.
Lisa Pohlmeyer
C3D 2012 SP4, evaluating C3D 2015
Please use "Accept as Solution" if this solved your issue.
CrazyIvan
Message 4 of 5 (73 Views)
06-19-2013 11:02 AM in reply to: LisaPohlmeyer
Sounds like a plan. I appreciate it.
*Expert Elite*
neilyj
Message 5 of 5 (62 Views)
06-19-2013 12:16 PM in reply to: CrazyIvan
Set modifiers for Object layers in your template - very useful
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
