Dear Friends,
I'm new in Civil 3d, just learning by myslef by following tutorials, I've a provlem, after creating existing profile, when I'm going to create design profile I want to draw tangents(VIPs) on my desired chainages and elevation by given command, specify start point and I write 0,376.00 0 means chainage 0+000 and 376.00 is elevation but civil 3d shows a message "point is ouside profile view try again, please can any one tell me the exact problem and how can I solve this, reply will be highly appreciated.
Solved by Jay_B. Go to Solution.
It's possible that your profile view isn't tall enough to encompass the elevations that you're trying to enter. Select the view and right-click to open the profile view properties. Switch to the elevations tab and you will be able to manually change the display range.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Dear J_B
can you tell me how can I bring transparent commands toolbar on my model screen.
Looking forward to your reply.
