Use P/C to set the level at whigh you may want your users to be able to make
changes. If you want more stringent control then apply higher in the tree.
There may be a few instances where you would want to create children
directly. Don't bind yourself, make your system as flexible as possible. If
you make it easy for your users they should not have to create "on th fly".
It is a wash as far as the amount of styles, they are being created either
way... as parents or children.
"Rick Graham" wrote in message
news:5047216@discussion.autodesk.com...
All,
I've been pouring over whatever documentation I can get my hands on
regarding Parent/Child relationships, but for some reason the 'lightbulb
hasn't come on yet'. 🙂
I understand the Parent/Child relationship... it's the how do I implement
them that is causing me grief. After creating a style that had many
variations, I thought the this would be a perfect application of the P/C
thing. So, I start looking at what else I've already done and how the P/C
thing would improve things.
Take contours for example: We have 3 scenarios in our office that we use
different 'styles' of contours - existing, proposed temporary (for E&S), and
proposed (for all other types). Within those 'styles' I have labels which
are handled differently. Slant text at one height and layer for existing,
regular text at a different height and layer for the proposed.
Would I create a style called CONTOURS, and then have children with existing
and proposed?
Line labeling is a similar thought process which is causing me to get the
extra strength Tylenol out. I imagine it would be the same for whatever
feature you are tre trying stylize.
So how are you all handling the P/C relationship or are you simply creating
431 different styles under each feature?.
...and I thought my child-raising years were over! 😉
Rick
