Civil 3D Forum
This is why I use 0.00001 for zero thickness on sub assembly
6 REPLIES 6
Joe-Bouza
441 Views, 6 Replies
Joe Bouza
6 REPLIES 6
tcorey
in reply to: Joe-Bouza
Yes, there are places where Civil 3D does not allow 0 thicknesses. Maybe someday...
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
sboon
in reply to: tcorey
There are a fair number of places where you cannot use a 0 width either, even though it would be appropriate for some designs.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
fcernst
What are you trying to do here Joe? What are your subassembly settings?
Here's mine:
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Joe-Bouza
in reply to: fcernst
Hie Fred
Nothing special. In this particular case I wanted to overlay only from the curb so I only wanted a top "layer" in the widen strip because I wanted to see the difference between a set thickness and the projected overlay (you may have noticed it does not mill) But what I am doing isn't at issue. In an earlier post Peter mentioned that layers can be set to 0 if you didn't want them seen or modeled. I was only showing that, at least up to 2013 assemblies look odd when absolute zero is used.
Joe Bouza
fcernst
I still need to see your settings to be clear.
So are you saying if you have a top layer of some thickness greater than zero, with all other layers zero, it doesn't work?
Fred Ernst, PE
C3D 2024
Ernst Engineering
fcernst
That subassembly appears to still have problems in 2014 also...
Here's how it looks in Layout and Section View for the settings I show below where I am just trying to create a 4" Pave 1 depth. It still creates the other Materials:
Fred Ernst, PE
C3D 2024
Ernst Engineering
Rail Community
