The AutoCAD C3D fails to apply the precision for all elevations in one go!
I wanted to let the precision to be zero for all the contour lines in ONE go but sound not to work!
Only the picked elevation responds to the selected precisions, the others are not affected!
What might be the problem?
The screenshot below shows the steps I did. the dwg file is attached.
Thank you for the help,
Best
Jamal
It looks as if someone else labeled the contours for you? They are probably a label style. If so, go to Toolspace-Settings Tab-Surface-Label Styles. Find the style that was used and right click, edit, layout tab, Text contents and click Text component editor (the three dots). Then highlight the text and modify the precision. I attached an image.
Thank you guys for the help. Your answer has resolved my issue.
I like your screenshots “pserpas”! Quite useful.
Best
Jamal
