Civil 3D Forum
Text Visibility
7 REPLIES 7
Message 1 of 8
rcallison
383 Views, 7 Replies
Text Visibility
I have a project where the MTEXT and leader is visible in model space. However when I go the the tab the text is not visible.  I have checked the layers and all are thawed.  If I explode the MTEXT leader it becomes visible in the tab.
Any suggestions would be appreciated.
Thanks.
7 REPLIES 7
Message 2 of 8
Jay_B
in reply to: rcallison
If you double click into VP and go to VP Freeze column is it thawed there?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 8
rcallison
in reply to: Jay_B
Yes,
I tried that.  If I explode the mtext it shows up. I point that out because when exploded the leader and text are in the same layer.
Message 4 of 8
Jay_B
Anyone's guess as to what may be happening.
Have you tried an Audit?
What version are you on?
Is this an Mleader or Mtext and is it directly in MS of current dwg or in an xref?
Can you post the dwg for someone to take a look?
C3D 2018.1
C3D 2016 SP4
Message 5 of 8
in reply to: Jay_B
Possibly the Annotation Visibility isn't activated?
Message 6 of 8
gccdaemon
I woukld say that the annotative properties are on, and that's the problem. However if you exploded it, then it may not be. If you don't have the same exact name for your annotation scale as you do for your viewport scale (despite having the same numbers), then items will not show through the viewport.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 7 of 8
in reply to: gccdaemon
I've had the same problem with the names being different, even if the definitions are different ie mm or m, then they won't be recognized. Sent from Samsung Mobile ________________________________
Message 8 of 8
gccdaemon
If messing with annotative scales works, don't forget to check solved. TY 🙂
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Rail Community
