Hey guys, just wondering if any of you know the command that I can use in order to align my text in papr space. I'm running 2011 and 2013 C3D. I have several callouts that are in a row, and I COULD draw a line straight down and just move them all to it, but that's a very inefficient way of getting this done. At the last company I worked, we had a command in the system simply called LINEUP that would align any text we wanted either horizontally or vertically. If this is a button I can create with code or whatever, I could try to do that too, if necessary. Just might take me a while to do the code, but I know there's a more efficient way of performing this task. Thanks!
Pick the multiple text objects, go to Properties window. Find the Position X (or Position Y) box and type a coordinate. All text objects will align to that X (or Y) coordinate.
Resist the urge to select the button that lets you pick the location in the drawing. This sets both X and Y to the same point so the text ends up on top of each other.
Tim
I see, but I forgot to mention that these are leaders, I don't have an x,y coordinate to align with in this case. Thoughts?
Are they Leader or Multi-leaders?
Use mleaderalign command.
