Civil 3D Forum
Text Alignment in Paper Space
6 REPLIES 6
civilengineer83
1208 Views, 6 Replies
Hey guys, just wondering if any of you know the command that I can use in order to align my text in papr space. I'm running 2011 and 2013 C3D. I have several callouts that are in a row, and I COULD draw a line straight down and just move them all to it, but that's a very inefficient way of getting this done. At the last company I worked, we had a command in the system simply called LINEUP that would align any text we wanted either horizontally or vertically. If this is a button I can create with code or whatever, I could try to do that too, if necessary. Just might take me a while to do the code, but I know there's a more efficient way of performing this task. Thanks!
Tags (1)
6 REPLIES 6
tcorey
in reply to: civilengineer83
Pick the multiple text objects, go to Properties window. Find the Position X (or Position Y) box and type a coordinate. All text objects will align to that X (or Y) coordinate.
Resist the urge to select the button that lets you pick the location in the drawing. This sets both X and Y to the same point so the text ends up on top of each other.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
civilengineer83
in reply to: tcorey
I see, but I forgot to mention that these are leaders, I don't have an x,y coordinate to align with in this case. Thoughts?
tcorey
Are they Leader or Multi-leaders?
Tim Corey
Redding, CA
civilengineer83
in reply to: tcorey
Multi-leaders
tcorey
Use mleaderalign command.
Tim Corey
Redding, CA
civilengineer83
in reply to: tcorey
Awesome, thanks, I appreciate the help. Did exactly what I needed.
Rail Community
